1/16 switch for new pc card!
satesco
Hi Hackbart,
I do not know if DVBViewer supports all functions for TBS6925 card{which is now undergoing tests},but I want to know if 1 / 16 switch{for toroidala} can be used with this card?I tried to configure TransEdit for 16 LNBs but only two satellites have been able to scan.It is a different procedure than the usual configuration?Or what I missed I can't use the switch for 16 lnbs?
best regards
Edited by satesco
..no problem with transedit or DVBViewer though the card has to support diseqc 1.1 or 1.2 depending on the switch.
