SergeyKa Posted May 19, 2011 Posted May 19, 2011 I'm switch on upnp logging and see what several messages has duplicate. What's problem? UPNP RS 1.7.2/Win 7 --------- 19.05.11 07:43:41.076 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.076 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.076 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.076 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.919 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.919 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.919 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:41.919 WSocketDataAvailable M-SEARCH * HTTP/1.1 MX: 3 ST: urn:schemas-upnp-org:device:MediaServer:1 HOST: 239.255.255.250:1900 MAN: "ssdp:discover" 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0 19.05.11 07:43:42.513 HandleMessage HTTP/1.1 200 OK SERVER: WINDOWS/6.0 UPnP/1.0 DVBViewer/1.0 ST: urn:schemas-upnp-org:device:MediaServer:1 CACHE-CONTROL: max-age=1810 EXT: USN: uuid:B239E649-BE9C-455D-9B9B-AB78821C8823::urn:schemas-upnp-org:device:MediaServer:1 LOCATION: http://192.168.1.103:8889/description.xml Content-Length: 0
Lars_MQ Posted May 19, 2011 Posted May 19, 2011 what makes you even think there is a problem. It's the UPnP log. It does log the UPnP happenings. All perfectly normal and you shouldn't mess with things you don't understand
SergeyKa Posted May 19, 2011 Author Posted May 19, 2011 TNX... I was trying to watch scrambled channels on my WDTV Live. And I'm found in svcdebug.log next Error messages: 19.05.11 07:43:53.810 TBDACITTModuleSingle:Create CloseCI: Системе не удается найти указанный диск (System can't find the specified drive) 19.05.11 07:43:53.810 TBDACITTModuleSingle:Create OpenCI: Недостаточно памяти для завершения операции (Not enough memory to complete operation) What does this mean?
