How to skip home window to directly go to HTPC mode?
Fabien44
Hello,
i would to use exclusively HTPC mode but every time i open DVBViewer in OSD mode, i see the home window with HTPC entry. How can i access directly to HTPC mode?
Thanks
Simply add the proper action into DVBViewer Desktop Icon commandline:
C:\[your language program path]\DVBViewer\DVBViewer.exe -f -x2110
where:
-f is for start in fullscreen mode
-x2110 open the OSD-HTPC page
You can find all the action codes in "actions.ini" file you find in the main DVBViewer folder...
You can also create more than one DVBV Desktop Icon and use them to command DVBViewer, as if DVBViewer is alreay started the actions are executed in the current session, ie you can create icons to tune a channel, to open OSD-Music , to mute it or whatever else you want...
:bye:
