DVBViewer won't start
Andy B
Hi there
I have an issue with DVBViewer, I recently installed the current version 4.8.0.1 and also installed the Skype plug in. When I exited the program and reloaded it, the loading screen seems to get stuck on 'Initializing OSD Skin'
I have tried restarting my computer and reinstalling the program to see if it will make a difference, but it has not. I've enclosed a support zip.
Appreciate any help
Thanks
Andy
Edited by Andy B
I had similar issues a while back ...I had been messing with different codecs ....I think there is an xml file which holds all the details and if you rename it will create a new default one, maybe sysop can give a clue. All the hardware config is in C:\Users\Frank\AppData\Roaming\CMUV\DVBViewer (for me on W7).
:bye:
Frank
Thanks for your reply, I've managed to resolve it by uninstalling again but deleting all folders with it, which seems to have done the trick. That'll teach me to install plug ins! lol
Thanks for your help.
