New newOSD & osdTimeline Versions
Guest Lars_MQ
I updated the newOSD and the Timeline plugins in the membersarea.
newOSD for DVBViewer
The newOSD plugin replaces the standard-OSD of the DVBViewer. It enhances the DVBViewer with a skinable Onscreendisplay and a interface to enable other plugins, to use the OSD easyly.
Versionhistory
Version 0.9 RC2
Fix: Text of osdTimelinePlugin is cut at the comma
Add: Renderer: Outline for Text
Add: Renderer: Outline forRoundrect
Add: Renderer: Outline forEllipse
Add: Renderer: Outline forRect
Add: Renderer: Qualitysettings for Bitmap, Font and Curves
Add: Fileformat: Added parameter Line for Linethickness
Add: Fileformat: Added displaytype Presentremaining
Add: Help File
Add: Inifile: Textqualitycontrol
Add: Inifile: Imagequalitycontrol
Add: Inifile: Graphicsqualitycontrol
Add: Help File
Remove: Fontformat: Removed unused Parameters.
Optimized Ini-File Handling for faster shutdown.
- overall performance finetuning
osdTimeline for DVBViewer
The osdTimeline plugin shows a graphical overview of the EPG similar to the new epgTimelineview of the DVBViewer in the OSD. The osdTimeline is able to switch between the channels and to send selected programs to the PVR.
Versionhistory
Version 0.9 RC2
Fix: Recordbutton showed for EPG of the past
Fix: Missaligned text in detail mode
Add: if language in DVBViewer is not german, the english captions are used.
Add: Keyhandling for OSD Enter. Switches now to the current selected channel
Add: Help german / english
Fix: The Setting "Channel excluded from EPG" of the DVBViewer is taken into account.
Fix: the changes in the Channellist are shown properly without need to restart DVBViewer.
Fix: Optimized Inifile handling.
The osdTimeline needs the newOSD 0.9rc2.
Both Plugins are german/english (If another language than german is selected the english text will be displayed, sorry that are the only two languages I know ;) )
Everything else is explained in the helpfiles.
Have fun
lars
Guest Lars_MQ
I've uploaded a small bugfix for the osdTimeline (0.9rc2a).
Channelswitching with OSD open/Enter was not working properly.
lars
