Fabien44 Posted May 26, 2011 Posted May 26, 2011 Hello, i use a DVB-T dual tuner card and watch divx. I know that some codecs can produce some weird behavior or crashing. Could you advise me some codecs pack or standalone to provide me the best stability of system? Thanks Quote
Griga Posted May 26, 2011 Posted May 26, 2011 It depends on what you actually need. It is recommendable to install decoders and other DirectShow filters in a targeted way, not blindly. ffdshow will cover most of what you need. Under start menu -> ffshow video/audio decoder configuration -> codecs you can select easily for what it shall be used. A demultiplexer/splitter filter like Haali may also be useful, and under certain circumstances the DivX Codec Pack, that contains a good H.264 and AAC decoder. However, you have to take care to untick the additional stuff that it wants to install. Quote
