Move a button
McenterFreak
It would be nice if the Save button was moved a little bit up and rigth (see atached). As it is now, I need to use the slider everytime i plan a recording. I know i could do it myself, but it is overwritten every time a new version arrives. So it could be nice if it was included in the distribution
Unfortunately that's not possible, because this part is not visible for other time types. But I did enlarge the timer edit window, so it should work better now.
Thanks!
YES!!.. good idea :) I thought it had someting to do with my set-up..
