burns Posted May 27, 2011 Posted May 27, 2011 (edited) I have the following problem: I have set up Recording Service on my PC, to stream TV to my Iphone. On my Phone I have access to the web interface. I can choose a TV station and start the stream. But when I start, the Iphone asks to push the start button - but their isn't any button, only a black screen (like a video window - but no action). Can anyone help me? Edited May 27, 2011 by burns
Lars_MQ Posted May 27, 2011 Posted May 27, 2011 Please post some more information: http://www.DVBViewer.tv/forum/index.php?showtopic=2210
Lars_MQ Posted May 27, 2011 Posted May 27, 2011 Did you follow this description? http://en.DVBViewer.tv/wiki/IPhone/iPod/iPad_Support
burns Posted May 28, 2011 Author Posted May 28, 2011 Yes, i have used the suggested Version of FFmpeg. I copied it in the root directory of DVB, because the DVBVservice.exe was in this folder.
burns Posted May 28, 2011 Author Posted May 28, 2011 The problem is solved - the ffmpeg wasn't in the folder (although I have copied it - the other files of the library are in the folder - many files...). After vopying it works. Thank you
