walick Posted May 30, 2011 Posted May 30, 2011 Am I only user who have a problem with MiniEpg in EVR on windows 7? Then I change channels between SD and HD quality MiniEpg change own resolution too between 576 and 1080, and sometimes not appear and only I can do is to press a ChannelList button. If i switch to EVR CP or Overlay renderer then no problem with MiniEpg any-more but, cannot use it because hardware acceleration works only in EVR in Win7. Did some1 have same issues? Quote
desweil Posted May 30, 2011 Posted May 30, 2011 thatÄs why you should use the custom EVR which DOES work with hardware acceleration Quote
walick Posted June 1, 2011 Author Posted June 1, 2011 Hmm... i have a lot of jitters without processor overload and no dropped frames then i choose EVR CP Cannot find something like FAQ "how to set up DVBViewer" with EVR Custom in Windows 7... Quote
