No DVB-IPTV in the dropdown list in the channel scanner
Hi all,
Under a fresh install of DVBViewer pro 4.8.0.1 on seven 64b, I have no choice for DVB-IPTV in the channel scanner only cable, satellite, tnt, atsc. I have no device hardware on the pc, only IPTV.
Edited by ulysse
I agree but it was in 4.5 and if you take a look to my previous post I cant import a channel list exported with transedit.
Why? What's the problem?
You don't have to import a channellist in DVBViewer. Simply use the Add/Update command in the TransEdit scanner window.
I've just discover this method too ;)
But in the Channel list, there are still big numbers ( as frequency's ) instead ip numbers, same in channel list editor and port in symbol rate box ...
Those "big numbers" are the IPs 32bit representation, don't mess with them.
