hackbart Posted June 2, 2011 Posted June 2, 2011 We have released the new DVBViewer Pro 4.8.1 today. ATTENTION: You can download the DVBViewer Pro 4.8.1 only from https://www.DVBViewer.tv/members/ We introduced a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: http://www.DVBViewer...ew-credentials/ Mit der Version 4.5 wurde ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: http://www.DVBViewer...-benutzerdaten/ The changelog: MHEG5 We finally added MHEG-5 support to the DVBViewer. What is it?MHEG-5 is a TV middleware and modern replacement of the old teletext. It is used in the UK, New Zealand, Hong Kong, Australia, Ireland and Germany (via Technisat Multytext on Astra 19.2°E). A video presentation can be found here: How to get it?The MHEG-5 plugin is a third party add-on and has to be ordered separate. To do so, open the key tool and press order, next to the MHEG-5 entry. Attention: Keep in mind that the license is bound to the email which was been used to buy the DVBViewer! After the transaction has been completed, the downloadable content will be unlocked for your DVBViewer member account in the DVBViewer members area (https://www.DVBViewer.tv/members/).Once the installation process is done, the personal plugin key you got via email has to be entered inside the keytool. You have to make sure that the code corresponds with the one you got provided by us. A triple-digit CRC Checksum indicates if the entered key is correct. MHEG-5 Fix: Stopped graph on radio playback Fix: Problem with ISO default language setting Fix: Time difference caused by summer time Fix: Audio 100% problem on BBC MHEG Fix: Problems with the videowindow while MHEG is active on Irish channels Add: Partially support for interactive channels (not finished yet) General Change: EPG.dat: The PDC PIL (if present) for EPG entries is saved in the epg.dat. Change: BDA-Hardware: EyeTV devices with CI are now handled like Twinhan/Terratec devices , MMI should work now. Change: Adjust PAT/PMT: The ECM Descriptors are now removed from the PMT if "Adjust PAT/PMT" is activated. Change: TS-Recordings: TS recordings now start always with a PAT/PMT. Fix: EPG-Parser: Fix for polish EPG by Griga. Add: Arib Subtitles: Do work now for real. Fix: DVBViewer Recording Service: Connection to the local recording service now doesn't use the windows proxy settings anymore. Change: Wizard: Simplified the hardware selection in the wizard. Change: DirectX Options: Changed the selection of media file types the DVBSource Filter should be used for. Fix: Video playback without the DVBSource Filter: Griga fixed several problems with the IAMStreamSelect interface. Add: Teletext: Added Grigas improvements to the teletext parser. Fix: Video/Audio A/B: Fixed a bug in detecting the correct file extension. Add: Datamanager: Added #TV.Timeshift.relativepos a float value (0..1). 0 means timeshift is at the beginning of the timeshift file, 1 means timeshift is at the liveTV position. Fix: OSD-Teletext: On jumping to page 100 with the OSD-OK key the internal input buffer for the teletext page numbers is reset now. Add: BDA Devices: Added detection of several new TBS devices. Add: OSD Channel EPG Window: You can now programmatically select which channel EPG should be shown by setting #OSD.channelnumber to the wanted channel number. Attention: The caller is responsible to set the value to empty or -1 after use. Change: Playback: For mp3 playback with the DVBSource Filter the graph is not rebuild if the old one can be reused. Updated to current sqlite3 version. Update to Version 3.5.5 of the DVBViewer Filter. Several corrections and optimizations. Language files updated. <g:plusone count="false" href="http://www.DVBViewer.tv/forum/topic/45849-DVBViewer-4810/"></g:plusone>
