uglyned Posted June 5, 2011 Posted June 5, 2011 Hi, Is anyone else having the same problem as me? On DVB-S, if I press red to see the MHEG overlay, one option is sports overlay - I think it's channel 3001. When I select it, the channel changes correctly to the STREAM-6 channel, but the MHEG application exits and I'm just dunped on that channel. DVBViewer doesn't seem to think that there is an MHEG stream on the BBCi transponder but surely that can't be right? Or is the MHEG application supposed to keep running once the switch to STREAM-6 has happened, despite there being no MHEG stream on that txp? Or is there something wrong in my setup?! Quote
uglyned Posted June 5, 2011 Author Posted June 5, 2011 Can anyone comfirm that this works for them? Just so I know it's a problem here? Quote
amontillado Posted June 5, 2011 Posted June 5, 2011 (edited) I have exactly the same problem. If I tune directly to STREAM-6 MHEG won't start either. I had a look at the transponder, 12441V. There is MHEG for STREAM-0 but not for the rest. Maybe its meant that for those additional stream mheg data has to be taken from stream-0 ? Edited June 5, 2011 by amontillado Quote
hackbart Posted June 5, 2011 Posted June 5, 2011 Could you check of the portal channel has some Mheg content? I suppose not, which means BBC uses the ability to keep the existing App in memory. It is quite annoying not to be able to receive the stream i will create a dump tomorrow via Remote pc in order to find a solution... Quote
