Slow frequency change
cspetee
I use 4.8.1.0 and DVB-C.
The channel change is fast if frequency don't change but it takes 7-8 seconds when frequency change and "not responding" warnings from windows but it disappear when channel changed.
The last good version is 4.5.0.0
TV-card: TerraTec Cinergy HTC USB XS HD with 5.09.1202.00 driver
Mainboard: Gigabyte GA-EP45-UD3P and Intel P45 chipset with 9.​2.​0.​1030 driver
Graphics card: Gigabyte GV-R485MC-1GH (Radeon HD 4850) with 11.5 catalyst driver
OS: Windows 7 Ultimate x64
  • 3 weeks later...
same problem here, but if you try progdvb you will see that channel change is very fast.
Too bad that DVBViewer makers does not have an terratec htc tuner to test it with progdvb to see how quick is channel change.
progdvb: 1 sec on same transponder, 1-3 sec on differents transponders including HD.
  • 3 weeks later...
DVBViewer Is The Best Ever I've Used !! The Problem Must be from your hardware
DVBViewer: 400 millisecond on same transponder, 700 millisecond on different transponders.. 900 millisecond On HD
Edited by kasper17
Please read first before comment!
If you can't help don't write anything.
