tsan2 Posted June 7, 2011 Posted June 7, 2011 Hi, There is 'Open Video' command on the DVBViewer menu. With 'Open Video' command I can select with mouse mpeg and ts files (not recorded with DVBViewer) and play them. This works ok. I don't see the same command on OSD. Is there a setting to get 'Open video' functionality to OSD? I would like to play video files using remote control and OSD. OS is Win 7 64bit ENG and DVBViewer is 4.8.0.1. This is a fresh install with default skin. I don't have any tuner installed as I only want to use OSD to play files recorded elsewhere. Is OSD the same than Fullscreen? I dont see OSD on DVBViewer menus. Support file is attached. support.zip Quote
Tjod Posted June 7, 2011 Posted June 7, 2011 Add the folder with the videos to the OSD http://en.DVBViewer.tv/wiki/Options_Movie_VirtualPath Than coe can open the videos via osd menu > htpchome > movies Quote
tsan2 Posted June 8, 2011 Author Posted June 8, 2011 Thank you for the information, I got it working now. I had virtual paths set but somehow I didn't see htpchome on menu. After playing with OSD menu options it works ok. Best regards, Timo Quote
