cooli Posted June 10, 2011 Posted June 10, 2011 (edited) Hello, Is there any way to record continously ? What I need is to record a channel each day, but using a timer I only can record from "00:00" to "23:59". How can I record the missing minute ? Thanks for your help. Edited June 10, 2011 by cooli Quote
Tjod Posted June 10, 2011 Posted June 10, 2011 Make two timer timer-1 "00:00" to "12:05" timer-2 "12:00" to "00:05" Quote
cooli Posted June 10, 2011 Author Posted June 10, 2011 Ok but when will timer2 start ? Right after timer1 ??? Quote
Tjod Posted June 10, 2011 Posted June 10, 2011 At 12:00, you can run multiple timers on one tuner simultaneously. It is possible to record all channels from one transponder (frequency) if thy are not encrypted with one tuner. Quote
cooli Posted June 15, 2011 Author Posted June 15, 2011 Just tried your solution but it's not very convenient because after that I need to join these files. Is there any other solution ??? I don't really understand why there's no way to record the full 24h :-( Quote
Tjod Posted June 15, 2011 Posted June 15, 2011 All recordings are internel headeld as timer. And with the timer format only 23:59 are posibel. Quote
majstang Posted June 15, 2011 Posted June 15, 2011 Just tried your solution but it's not very convenient because after that I need to join these files. Is there any other solution ??? I don't really understand why there's no way to record the full 24h :-( Well, you can always try my "Scheduling seconds script for RS" here: http://www.DVBViewer.tv/forum/topic/41552-scheduling-seconds-script-for-rs/ It's quite old but should work on Win7 32bit. If you have 64-bit there could be problems. You should be abled to record from 0:00:00 to 23:59:59, only missing 1 second with it. Quote
