Series and UPNP
jmetsako
Been using "series" view with UPNP, now after RS 1.8.0.1 update I'm not able to browse series with UPNP client, all other category's are there and working like "by channel and by genre". Could some one cross check is this possible bug or do I have some how corrupted installation.
br.
Jani
works here. maybe your (video) database has become corrupt or the service doesn't find the database of the myseries plugin (if you use it).
Deleted media database, but no luck
Looks fine in browser
But not anymore in XBMC
So do I have to wipe whole install directory or do you have any hints or suggestions?
Many thanks
Jani
videofiles <> recordings. Don't use the video part in UPnP, use the recordings part. Or define you recordings folder as video media folder in the recording service configuration program.
Hi, xbmc picture miss leads. Picture is actual from under recordings, it just not "publish" series category. If I do like you suggested, add recordings folder under video media, then it's possible to browse media sorted by series but then there is no "info" from files.
btw is there any change to get series view support to native client?
br
Jani
