merovingi0 Posted June 13, 2011 Posted June 13, 2011 (edited) often, when I start DVBViewer 4.8.0.1 (purchased it from the site) on Windows 7 64bit SP1 Enterprise Edition, i get this message: "no hardware available" I have to reboot the program or restart the computer several times and everything goes back to work. Do you have any advice? support.zip Edited June 13, 2011 by merovingi0 Quote
Derrick Posted June 13, 2011 Posted June 13, 2011 ..when using the recording service, the hardware has to be deactivated in the DVBViewer (hardware options -> don't use) and be replaced by an unicast device. Quote
Tjod Posted June 14, 2011 Posted June 14, 2011 http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
desweil Posted June 16, 2011 Posted June 16, 2011 just follow the installation guide (the links Tjod posted) step by step. It's not rocket science! Quote
desweil Posted June 21, 2011 Posted June 21, 2011 ? If you want to use the Recording Service then you have to configure it properly. Or deinstall it. Quote
merovingi0 Posted June 21, 2011 Author Posted June 21, 2011 my problem was not with the Recording Service. my problem is that sometimes when I start the DVBViewer I get the message "no hardware available", and I have to restart the program several times, or the PC. Quote
Derrick Posted June 21, 2011 Posted June 21, 2011 ..maybe another application is claiming your device in the background (e.g. MCE) ? If that's so, you have to deactivate mce. Quote
