stefabona Posted June 15, 2011 Posted June 15, 2011 (edited) It happens, only sometimes, that when i change to a dvb-s to a dvb-s2 or from a dvb-s2 to another dvb-s2, that DVBViewer hangs, othing is diplayed on the screen (black screen) and the remote is no more responding. If i click with mouse the s.o. tells me that DVBViewer is not responding and i have to force close it. Some suggestion? My configuration: skystar hd2 intel core2duo 4gb ram ati 3650 hdcp vga ssd kingston ssdnow 64gb DVBViewer 4.8.1 (actual version - but i can confirm problem is present from 4.3 version, the first i installed - before i don't know) ---- EDIT ---- i typed wrong in the title... is there a methos to change it?!?!?!? ----- EDIT ----- Edited June 15, 2011 by stefabona Quote
tomas.jurksas Posted June 15, 2011 Posted June 15, 2011 Try in shortcut properties set compatibility Run As Administrator Quote
stefabona Posted June 15, 2011 Author Posted June 15, 2011 Uhm... even if i have uac disabled? Anyway, i will try this... Quote
