ashc09 Posted June 17, 2011 Posted June 17, 2011 (edited) Hi, wondering if anyone can shed some light on this matter, basicly when i record a tv show for say an hour, instead of getting 1 file, im getting lots of files, sometimes as many as 6 and sometimes just 2, does anyone know why this could be happening? i have just had to reinstall windows 7 and it was perfectly fine before, i have upgraded to the new DVBViewer version, thats all.. Support file attatched.. Hauppauge Win-TV Nova HD-S2 x2 (Latest Windows 7 Driver) Asus P6T Deluxe V2 Motherboard Nvidia GTX 295 (Latest Driver) thanks everyone... support.zip Edited June 17, 2011 by ashc09
Lars_MQ Posted June 17, 2011 Posted June 17, 2011 16.06.11 18:56:02.107 TRecording.Tick No data within one minute, restarting! You have problems with your DVB Hardware and/or Reception and/or Driver.
ashc09 Posted June 17, 2011 Author Posted June 17, 2011 Hi, Oh ok, il take a look into it then, thanks alot for diagnosing that for me.. Ash
wgk Posted February 20, 2013 Posted February 20, 2013 Hi, I've the same problem. Any findings or solution which you might share with me?
