DVBViewer dont find any S2 on 4,8E
hejhopp1
Hi!
Im trying to get DVBViewer to find dvb-s2 channels on 4.8e but with no luck.
i have the latest 0048.ini from http://satellites-xml.eu/ and it has for example
33=12341,H,27500,34,S2,8PSK
but DVBViewer just don't grab the channels on that transponder.
I have no problem geting s2 channels from 0.8w.
I installed ProgDVB 6 and it did not have any problems finding s2 on 4.8e.
Any one have any suggestion on what to do?
I have a Hauppauge WinTV HVR-4400 HD card.
//hejhopp1
works!! thx
how did u know about the 134?
//hejhopp
..apparently your card/driver needs the additional modulation parameter pilot symbols "on" that is not part of the standard lists because it's not listed in the satellite delivery system descriptor. 134 is the DVBViewer notation for 8psk with pilot symbols on.
progdvb's transponder list either already contains the complete parameter set or the program finds the correct pilot setting by try and error ;)
oki, thx for the info and for the help.
//hejhopp1
