airstar
trevora
setup for pc shows sigal strenght 90 to 100%
so card recieving ok
start DVBViewer
do a scan of terrestrial (eur)
get list of about 90 video / audio channels
try to run a channel by double left click and error
EZERO DIVIDE RAISED BY INSTANCE TV CHANNELS OF CLASS
TTREEVIEW AT 02CA241A
If i try any thing from here pc freezes
on restart channel has gone
if i do scan, close DVBViewer, open again still channel list gone
pc is
amd 2000
556mhz memory
5200 graphics with 128 memory
airstar pci card
sorry this as to be my first post
have skystar running ok on wifes pc so finding this frustrating
if i can crack this will buy full version, but would like to prove it works first
trevora ;);):):(
1) Download the latest Patch for the DVBViewer Technisat edition:
http://www.DVBViewer.com/download/patch.zip
just replace DVBViewer.exe
If this doesn't help:
2) Download the RadLight Filter Manager, launch it an go to the DirectShow section of the tree view. Check wether a "Ligos Audio Decoder" is present. It is known to cause the error mentioned above. If yes, select it and click "Unregister". Have a look at the Log Tab to see which file has been unregistered, so you can re-register it later, if necessary.
Edited by Griga
22/08/2004 13:43:44 EZeroDivide raised by instance tvChannels of class TTreeView at 0B7A241A:Gleitkommadivision durch Null
22/08/2004 13:58:28 EZeroDivide raised by instance tvChannels of class TTreeView at 02CC241A:Gleitkommadivision durch Null
22/08/2004 15:59:54 EZeroDivide raised by instance tvChannels of class TTreeView at 02CC241A:Gleitkommadivision durch Null
22/08/2004 18:41:52 EZeroDivide raised by instance tvChannels of class TTreeView at 02CC241A:Gleitkommadivision durch Null
22/08/2004 18:45:54 EZeroDivide raised by instance tvChannels of class TTreeView at 02CC241A:Gleitkommadivision durch Null
22/08/2004 19:01:23 EZeroDivide raised by instance tvChannels of class TTreeView at 0298241A:Gleitkommadivision durch Null
22/08/2004 19:15:52 EZeroDivide raised by instance tvChannels of class TTreeView at 0298241A:Gleitkommadivision durch Null
22/08/2004 19:34:33 EZeroDivide raised by instance tvChannels of class TTreeView at 018B241A:Gleitkommadivision durch Null
22/08/2004 19:42:31 EZeroDivide raised by instance tvChannels of class TTreeView at 0192241A:Gleitkommadivision durch Null
22/08/2004 19:51:06 EZeroDivide raised by instance tvChannels of class TTreeView at 01B8241A:Gleitkommadivision durch Null
setup.ini
sorry for 2 parts
my operating system win xp sp2
cpu amdxp200 512 m pc2700 memory
filters dump.ax --dumper.ax
drivers airstar= 4.2.10.9999
radeon 7500 --6.13.10.6014
soyo sy-k7v --via apollo kt266a
DVBViewer te
I do a scan get about 90 video/ audio channels
double click on one and get
EZERO DIVIDE RAISED BYINSTANCE TV CHANNELS OF CLASS TTREEVIEW AT 027A241A
TREVORA
what other info do you need pleaser , then i will try to find it
