MHEG-5
KeithB
Hi
I have downloaded DVBViewer 4.8.1.0 and installed it, then installed the MHEG-5 download. I have use the key tool to try and unlock and pressed the "save" button.
If I click on EPG I still get the original EPG as before.
I'm not sure what to try next.
I did reinstal DVBViewer again and then the MHEG download again.
This is not a bug, if you want your NZ EPG Mheg application, press the "E" button (if not defined elsewise). The readme which is part of the mheg installation contains a list of all mapped key functions.
Christian
PS: If you do so, it will look like this:
Thank you very much. I did not see that in the readme-mheg-5.html.
Please accept my sincere appologies for wasting your time.
Best regards,
Keith
No Problem the key is not mentioned in the text file, only the function which is used to interact with the Mheg application:
Show EPG Australian/NZ Show EPG*
Show Mini EPG Australian Show EPG Info
Show EPG is by default mapped to button "E" - you can reassign it if you want under options -> input.
Christian
