stormynight Posted August 16, 2004 Posted August 16, 2004 Hello, i´m using the DVBViewer Technisat edition. After installing Windows XP SP2 German + DirectX 9.0c the recorded movie is wrong. The movie can be played, but the pic shows coulored squares. Any ideas ? Thanks Marko. Btw, whats the link to the german forum ? Quote
Klausing Posted August 16, 2004 Posted August 16, 2004 With which programm you can't play it? Had you a look that you havn't errors during recording? Please download the following smart programm and use it. It create a small textfile which shows the installed MPGDecoder which are important for playing MPGfiles. And BTW you can install the elecard Demultiplexer, which is much more kindly for playing MPG-files. whats the link to the german forum ?Look at http://www.DVBViewer.com/forum/ go a little bit down with your eyes and click on Deutsch. Steffen Quote
