jf2020 Posted June 21, 2011 Posted June 21, 2011 Hi, This is likely not DVBViewer per se related, but I hope someone can provide ideas about what's going on or help me with steps to find why it's not working. I cannot receive any channels from 19.2E 12522 V (tp 106 according to Lyngsat). A Transedit scan brings nothing for this transponder. I have no trouble receiving channels from transponders below and above. I am using a Skystar 2 HD USB CI. JF Quote
Derrick Posted June 21, 2011 Posted June 21, 2011 Do you use a recent standard astra transponder list (provided in the setup)? If yes, the problem could be related to rf-radiation from other sources or a kink in the cable. Check your outdoor equipment and all cables, switches and connectors. Quote
QBox User Posted June 22, 2011 Posted June 22, 2011 DECT phone interference can affect transponder frequencies between 12480 and 12500, so that's a little outside. 12522 downconverts to 1922 MHz: that could be cell-phone related - is there a mast nearby? Quote
