kemalettin Posted June 23, 2011 Posted June 23, 2011 i downloaded latest DVBViewer and installed prof tuner 7500usb (64bit win7) codec. its a fresh install win7 64bit tried with coreavc ffdshow arcsoft and default windows codects but not working!! Quote
ak2010 Posted June 23, 2011 Posted June 23, 2011 Try Downloading (Direct Show Filter Manager) and set the DVB Source filter as the preferred source filter (set merit to the top). When you install a new DVBViewer version you find (If like mine) that the source filter gets registered as do not use. You will know what i mean if you install DIRECT SHOW FILTER MANAGER Hope this helps!! Quote
ak2010 Posted June 23, 2011 Posted June 23, 2011 Just a follow up on previous reply, If you install Direct Show Filter Manager, Open it and double click filter. When new window opens you might have to drag the window to widen it on the right hand side to see merit bar. I think it was built for XP but works fine on Win 7 Quote
kemalettin Posted June 23, 2011 Author Posted June 23, 2011 thanks its working now for 422 feeds which codec do you recommend? Quote
