peterpr Posted June 23, 2011 Posted June 23, 2011 Hi I have managed to successfully record HD channels in .ts format. If I try to record SD channels in .ts format the file name is created but no data is recorded. If I record SD channels in .mpg format it works fine. I would prefer to use .ts format as this is much better for HD but this will cause a problem if I want to set up the scheduler to record a sequence of both SD and HD channels. The manual suggests using the .ts format - "This one is most advisable for further editing and error correction." Anyone have any idea of what is going wrong? Quote
McenterFreak Posted June 23, 2011 Posted June 23, 2011 I dont think you can expect any answers before you respect the rules http://www.DVBViewer.tv/forum/topic/2210-how-to-post-bugs-or-problems-correctly/ But my suggestion is that you dont have a working MPEG2 decoder Quote
