Dvbviewer + Skystar 2 HD + MOTSAT3
lordjohnny
Hi everybody.
I have installed in my pc DVBViewer PRO 4.8.1.0 and configured with SKYSTAR 2 HD in WINDOWS 7 ULTIMATE 64 BITS.
My dish size is 80 cm and this dish have installed a motor (MOTSAT 3 manufactured by ILLUSION) and i can't move the motor with DVBViewer.
I connected to the skystar 2 hd directly to the power supply (molex connector in the pci card) but i can't move the motor.
Anyone can say me how to move the motor correctly with de lastest version of DVBViewer?
Any manual?
Thanks you.
Regards, Alberto.
Edited by lordjohnny
Use the Positioner Console in TransEdit to see if it will move. The main TransEdit window will let you set up the satellites using angular or stored position.
