Instant Recordings to the Recording Service
Hello,
I would like to use the recording service also for the instant recordings.
In this way, while looking to a program, I can simply press on the REC button and then, even if I close the application on the client the Recording Service continue recording.
Is it possible?
Thank you,
Dakkar
The fastest way to send recordings to RS from client would be through the DVBViewer EPG. If bringing up the EPG, mark the show you want to record (leftclick) and then rightclick on it and choose "Send to PVR". If having "Send timers to service" checked in DVBViewer-->options-->Recording Service, the timer will be sent to RS. When that is done it's safe to close client. RS takes care of the rest.
