requirement
aziz5210
hey everyone
I am planning to buy skystar 2 pci card
MY SYSTEM
1.pentium 4
2.nvidia geforce 2
3.256 mb RAM
4.80 gb hard disk
5.5 usb ports
6.pci slot available
7.1.69GHz
8.windows xp professional SP3
IS THIS WILL BE BEST FOR BUYING SKYSTAR 2PCI CARD
THANKS IN ADVANCE
IMHO your PC is just enough for SD... would be better if you can expand RAM to 512Mb and video card to a NVidia Geforce 4 series: NV4 is way better than NV2 and is very cheap if you can still find it...
Anyhow you have to keep S.O. very "smart" and clean: stop any autostart program, install the latest DirectX and install/use only one video codec, NVidia own is the best for you video card...
:bye:
