McenterFreak Posted July 10, 2011 Posted July 10, 2011 In Recording Service webinterface it would be nice if there was a kind of "One Click Programming" in TV Guide view. As it is now you need to: 1. Click program 2. Move Mouse to red button and Click 3. Move slider down to locate Save button (should be solved with next release, where the window size is enlarged) 4. Move Mouse to Save Button and Click If not possible, it could be nice if Enter is defauling to red button in step 2, and Save button in step 4. Then no need to move Mouse. It would also be nice if in Reruns, the Add to Auto-Record search, was set to checked (or the last value), and the Name field was populated with the same text as in the Search for field. Finally it would be nice if Save wase the default for the Enter key Quote
Lars_MQ Posted July 10, 2011 Posted July 10, 2011 just deactivate the show timer window on the web interface -> configuration page. Quote
McenterFreak Posted July 10, 2011 Author Posted July 10, 2011 Fine,thank you So now it is only this small problem: "It would also be nice if in Reruns, the Add to Auto-Record search, was set to checked (or the last value), and the Name field was populated with the same text as in the Search for field. Finally it would be nice if Save wase the default for the Enter key" Quote
