delprops unicode support?
majstang
Hi!
I'm wondering about if the execellent little tool delprops supports unicode?
http://www.DVBViewer.tv/forum/topic/37814-aufnahme-dateieigenschaften-aendern/page__view__findpost__p__274824
When Lars made the utility (late 2009) the DVBViewer and Recording Service still was unsing ANSI encoding for the EPG information files .txt.
Here is the problem description:
- When updating metadata on "dummy".ts files in the recording database from the EPG information file using delprops, the Autosearch "Event" feature does not work.
- If i haven't deleted the original full sized .ts recording and use Grigas "PropCopy" to update the metadata from "orig".ts to "dummy".ts, the Autosearch "Event" feature works.
Could the difference between the tools be encoding related?
