Toastbrot Posted August 21, 2004 Posted August 21, 2004 Hi, I'm a beginner with DVBViewer TE/Airstar 2 DVB-T. As far as I see it works. If I use Technisat DVB Setup4PC it scans channels fast, after about 2 minutes it has all my DVB-T channels. With DVBViewer TE I wait and wait and wait and wait... How to scan the DVB-T channels very fast? :-) Quote
Toastbrot Posted August 21, 2004 Author Posted August 21, 2004 How can I control what I scan? Oh, I just used "Stammordner Terrestrial EUR". Scans for a while (STOP shown, SCAN greyed) than stops (STOP still shown/black, SCAN black, too). Looks buggy to me. Next problem: I choose a channel (let say ARD), get about 80 to 90% level. Video image is visible for about 2 seconds in motion, than it stops/freezes for 1 second, than 2 seconds motion again. Depending on my settings it stops with a black screen or a freeze image. I choosed different render engines or anything else I can change, no difference. I have a matrox p650, win 2k, of course latest drivers/bios. Quote
Guest Oliver Posted August 21, 2004 Posted August 21, 2004 Video image is visible for about 2 seconds in motion, than it stops/freezes for 1 second, than 2 seconds motion again. I choosed different render engines or anything else I can change, no difference. That could indicate you're not using the TE. BTW: You should post some more information. Have a look here for details: http://www.DVBViewer.com/forum/index.php?a...st=0#entry12632 Bye, Oliver Quote
Toastbrot Posted August 21, 2004 Author Posted August 21, 2004 My DBViewer TE has a settings->enhanced->render output I can choose between "unchanged" and "overlay mixer". Is there another TE? Quote
Guest Oliver Posted August 21, 2004 Posted August 21, 2004 No, there's only one TE, but I thought you'd spoken of different render cores (source-filters) and not the render output. BTW: The information (setup.ini...) is still missing. Bye Quote
