keveen Posted July 18, 2011 Posted July 18, 2011 (edited) I stopped using DVBViewer for a while because it started to freeze my PC. I upgraded to version 4.8.1 but the same thing is happening - my computer completely freezes and Ctrl Alt Del doesn't work and there is no hard drive activity. I have to restart by holding the power button. I can't think of a particular event that triggers the freeze. The computer has also crashed while recording. Also I can't stop a recording once it is started. I go to the Record button and click Stop Recording but nothing happens. The programme continues to record. support.zip Edited July 18, 2011 by keveen Quote
majstang Posted July 18, 2011 Posted July 18, 2011 Try to avoid using the EVR renderer on WinXP. EVR is for Vista/7, use VMR-9 or overlay instead. Quote
keveen Posted July 18, 2011 Author Posted July 18, 2011 (edited) Thanks I'll try that now. I just left everything at their default settings cos I didn't know any better. Edited July 18, 2011 by keveen Quote
