henryxp Posted July 22, 2011 Posted July 22, 2011 (edited) I have a PC used as a HTPC with a ATI Radeon 2600HD XT I use it for TV SAT, a program using DVBViewer Pro latest version, I am aware that if you set the video renderer of the VRM9 I "squadrettature" image, aliasing. On the ATI control panel Catalyst I have set up anti-aliasing but does not change anything. The video codec that I use are the Cyberlink 10, I have tried others, but the problem remains, to remedy the problem I set the video renderer of 'system default "but in doing so I lose the transparency of the menu 'of the OSD program. This happens on WinXP SP3, Seven would not have this problem, but another far worse, when you zap between CH HD program often pulling the plant down with the OS though, I have to reset. The PC SAT CARD is The SkyStar HD clone of TT-budget S2-3200 I am reading this guide on the wiki but realized I've got much http://it.wikipedia.org/wiki/Antialiasing http://en.DVBViewer.tv/wiki/ Greetings. Edited July 22, 2011 by henryxp Quote
