robertuswe Posted July 24, 2011 Posted July 24, 2011 Hi DVBViewer 4.8.1.0 ( last version ) without others programs like Recording Service, crash sometimes random ( not when start a timer ), but when i see only a channel My hardware: - Terratec 2004i DT ( Digital Terrestrial dual tuner ) - TBS HDTV DVB-S2 6981 ( Sat dual tuner hd ) Software: - DVBViewer 4.8.1.0 - Windows 7 64bit ( all updates done ) ( 4gb ddr2, q6600 2,4ghz, ati radeon 5670 hd 1gb ) - All drivers are up to date ( Terratec, TBS and others hardware ) Crash happend when i see an encrypted and fta channel. I use Microsoft DTV-DVD Video Decoder, except for AC3 where i use AC3Filter 1.63b ( i think last version, without ac3filter ac3 isn't play ) Render Video: EVR ( VMR-9 use a lot of cpu, evr is better for cpu, but i don't think that is render video the problem ) I hope that someone can fix this problem support.zip
robertuswe Posted July 24, 2011 Author Posted July 24, 2011 (edited) Have you the neutrino plugin in using? Neutrino? sorry i don't know this plugin [removed] Edited July 25, 2011 by Tjod § 13
Tüftler Posted July 24, 2011 Posted July 24, 2011 § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
robertuswe Posted July 24, 2011 Author Posted July 24, 2011 (edited) § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. useless this copy, there isn't any piracy in my post, so why you copy this? Edited July 24, 2011 by robertuswe
robertuswe Posted July 24, 2011 Author Posted July 24, 2011 Any other questions? [removed] it's ridicoulos also because I bought this program
Tüftler Posted July 24, 2011 Posted July 24, 2011 Please rename the plugin folder in pugin_1 or something else and start DVBViewer.exe with -debug. In case of appCrash post a new support.zip
