RS 1.9 Web API
majstang
It seems something has been messed up in RS API.
When RS is idle and client stopped...........Status=0, Clientcount=0
When RS is idle and client started...........Status=0, Clientcount=0 (clientcount should be =1)
When RS is in recording and client stopped...Status=1, Clientcount=1 (clientcount should be =0)
When RS is in recording and client started...Status=1, Clientcount=1
While you are already working on the API how about making these changes as well ;)
http://www.DVBViewer.tv/forum/topic/41329-after-recording-task-recservice-status-issue/page__view__findpost__p__329900
Edited by majstang
local client? If you don't use Block standby hibernate with local client... the local client will not be counted.
Aha, i have missed this new option on the DVBServer tab in configuration program completely. Thanks, Lars :bye:
