AleXNight Posted July 28, 2011 Posted July 28, 2011 Hi! When I record Digital TV with DVBViewer using a DVB-T USB Tuner by AVerMedia (model A867) I often get Stream Errors. The resulting TS file is corrupted like the picture attached . Is there a way to avoid these Stream Errors? I've got 100% DVB-T Signal for the channels I want to record from. I've got this setup: Aerial Antenna > Antenna RF Cable > USB DVB-T > USB Extension Cable > PC. May the extension cable degrade the signal from the USB Tuner to PC? In your opinion, what's the best DVB-T USB Tuner to use with DVBViewer? Budget: about 35 euro. Thanks in advance! Quote
