Freesat EPG collection
QBox User
I currently have my system designed to collect EPG data through the 12-hourly scheduled RS update. DVBViewer (on the same machine) is set NOT to collect EPG, but to load from RS. I have Freesat collection enabled in Options AND have "SFI, MHW+" reception enabled for all the channels with EPG display enabled. It works OK.
I should be able to capture all Freesat EPG data very quickly from the designated transponder (11427H on 28E). However, the EPG Update seems to want to scan all transponders with at least one channel having EPG Display enabled. (I'm guessing at this, since the svcdebug.log file doesn't give specific tuning details. Also, the separate EPG Update script scans about the same number of transponders and lists frequencies used, so I assume the methods are similar.)
Is there some way to make the Update more efficient, so it will complete in 30 seconds rather than half-an-hour? I could just schedule a 1-minute tuning task for the Freesat Info channel, but I'd like to keep using the Update if possible, to simplify collection from other satellites.
