Transedit and NA echostar sat issue.
SiN360
Hello I've been trying to scan echostar 110 and 119 with the latest TE and the SDTO-1 line. The result are pretty inconsistent I've also set the SDT time to 45000ms. I saw that a TE version for echostar was made, but it that was a long time ago. Does anyone have that that version to test out the scan to see if I get better results? Thank You
  • 3 weeks later...
I take it nobody uses DVBViewer in NA, so I bought something and can't even uses it fully.
Edited by SiN360
Maybe if you gave some more detail rather than "inconsistent". What works and what doesn't?
Do you have latest transponder ini files? The ones distributed can be well out of date.
