Can't install MHEG-5 plugin
kitesabbey
Downloaded the plugin, and received the key. When I try to run the Mheg5Setup.exe, it stops with the message "Setup has detected that MHEG-5 for DVBViewer Pro is currently running. Please close all instances of it now.". The only way out is to press 'cancel'.
Task Manager shows two instances of Mheg5Setup.exe and two instances of Mheg5Setup.tmp every time I run setup (they all close when I press 'Cancel'), if that is of any help.
Any ideas?
Close the DVBViewer and stop the recording service if you have it installed.
Thanks - perhaps this error message needs modifying.
