plankie Posted August 13, 2011 Posted August 13, 2011 Hi, I'm using the following setup: <LNB> -- <Stab rotor> -- <PC with TechnoTrend S3200> -- <DVBViewer Pro Server> -- <Network> -- <Laptop with DVBViewer client> 1) All is working like a charm, but from time to time I'm running into the problem of having no picture after channel change. It doesn't matter if change transponders or stay on the same. I did some investigation and found the DVB Source in state: (DVB Source 3.5.5.0) Video State: No data/connected Audio State: No data/connected Filter State: Running Last Error: None To solve this, I need to give a 'rebuild graph' command (which I already pre programmed as hotkey ) Is there a way to 'initiate automatic rebuild graph every X seconds' under those circumstances? This would also help when receiption has been temporarily unavailable because of either bad weather or a bird sitting on the LNB 2) Signal level would be a nice thing to see through DVBViewer server. It now only states 100% (or is it showing Signal quality? In that case, make it an option to switch? Quote
