automatic retune\rebuild graphic upon dicontinuities
ntcctnntcctn
Hi everyone.
I wonder whether it is possible for DVBViewer or recording service to rebuild graphics when discontinuities are detected.
Always, the DVBViewer starts with errors in graphics, but after rebuild graphics at most several times,
the DVBViewer functions properly.
However, it is not possible to click the 'rebuild graphics' buttom when one leaves the DVBViewer for recording.
So, is there any way that the DVBViewer can make sure the recordings can run properly? Or otherwise, the DVBViewer would be completely useless as it is even worse than TotalMedia.
First you should check to see where errors occur. causes of discontinuities are hardware or driver problem or a bad TV signal.
Here is my system info:
TV card: Hybrid DMB-TH PCI Express
Driver Version: 1.0.703.0
motherboard: intel DP965LT
graphic card: Radeon X1300
Version: 8.593.100.0
I have tried many ways to solve the discontinuity problem, but none works.
If discontinuity happens at starting, it continues until the end.
But if no discontinuity at starting, it works smoothly until the end.
Hopeless to get rip of discontinuities, the only way is to bypass it.
Let's start with: Upgrade Your XP to SP3
Next Step: update of the drivers of the tv card
driver
I have upgraded to SP3 and my TV card in fact is MyGica X8506 with driver updated.
but the problem remains.
In fact things become worse after update to SP3
