Is Skystar HD USB works with diseqc 1.1 (8 LNB's) ?
xXxXxXxXx
Currently J have SS2 and it's working with diseqc 1.1 (8 LNB's), but J want to replace it with DVB-S2 card
namely Skystar HD USB, so J've got a question:
Skystar HD USB works with diseqc 1.1 (8 LNB's)?
With the WDM (Network) driver it should work in any case, because the interface is the same as for the SkyStar2.
It may also work with the BDA driver under Windows 7, if the driver supports a new DiSEqC BDA interface introduced by Microsoft. A user report suggests that it does, but it's not 100% sure...
thank you for answer, but J really need to be sure before J buy this card...
