blitter Posted August 22, 2011 Posted August 22, 2011 (edited) Hi. Please does latest DVBViewer 4.8.1 shuts down the diseq power when the application exits? Edited August 22, 2011 by blitter Quote
Tjod Posted August 22, 2011 Posted August 22, 2011 Depends on the used tv card. http://en.DVBViewer.tv/wiki/Options_Hardware#Disable_LNB_on_device_releasing Quote
blitter Posted August 22, 2011 Author Posted August 22, 2011 (edited) I am using Tevii S464 PCI. Please do you perhaps know if it supports it? Btw that option is not present on DVBViewer 4.8.1 neither 4.5 under the Hardware options panel. Does the option only showes up if the device supports it? Edited August 22, 2011 by blitter Quote
Tjod Posted August 22, 2011 Posted August 22, 2011 As far as I know it is not supported by DVBViewer. Quote
Antonio Posted August 23, 2011 Posted August 23, 2011 I too asked a similar question. It appears there is a universal method, almost for all devices. CrazyCat69 just make 'fake' tune request with polarization=BDA_POLARISATION_NOT_DEFINED generic method, like technotrend, tevii and many other BDA drivers. Whether there is only an answer from developers DVBViewer they will introduce it in the following release? Quote
