LINUSJ Posted August 26, 2011 Posted August 26, 2011 Hi, I would like to buy Tevii S464 pci card and let it work with DVBViewer in order to see DVB-S2/8PSK channels. How is the card and how works with DVBViewer? I will very appreciate suggestions and what are your opinion on working card with DVBViewer Pro. Best wishes, Linusj Quote
QBox User Posted August 26, 2011 Posted August 26, 2011 The card is in the list of "Supported hardware". If you type the model number into the Site Search panel, you will find lots of comments. Quote
LINUSJ Posted August 26, 2011 Author Posted August 26, 2011 Thanks a lot, but many threads aren't in english languages. Hopefully in english. regards by Linusj Quote
QBox User Posted August 29, 2011 Posted August 29, 2011 If you send the pages to Google Translate, they can be translated to your native language. Google Chrome browser has built in option to use this feature. I use Firefox with an extension - just right click to translate a word or sentence I don't understand. Quote
LINUSJ Posted September 6, 2011 Author Posted September 6, 2011 Thank-you for suggestions. Just bought TeVii S464 and tested it with DVBViewer Pro. The card works perfectly on my system for hours without problems on DVB-S and DVB-S2. Quote
