Lord Kram Posted August 27, 2011 Posted August 27, 2011 For some reason I cannot seem to change the output size of any screenshots I capture in DVBViewer I'm sure I remember before re-installing I had a combination of filters/rendererer's etc which allowed me to capture screenshots at whatever the current window size was, but at the moment it seems to be fixed on 1920x1080 for any h264 sources and its stuck on 1024x576 for mpeg2 sources Any ideas? i've played around with different codecs/changing aspect ratio etc, all the renderer settings, but cant change the output Thanks Quote
Lars_MQ Posted August 27, 2011 Posted August 27, 2011 The snapshot size is always the same size the original TV picture uses. You can't change it. Quote
