Can DVBViewer dynamically assign tuners?
OllieB
I have two tuners plugged into my PC - one for Freeview and one for Freesat. Many of the channels are duplicated, but with different channel names and PIDs.
My question is, is there a way of setting up the channels so that, for example, I just have one instance of BBC One in the EPG, and if I set up a recording DVBViewer will automatically choose which tuner to use depending on which is available? i.e., I just need to set up a BBC One recording, without worrying about which tuner to use, and DVBViewer will automatically use the satellite tuner if it's not already in use, or the terrestrial tuner otherwise. Is this possible?
No BBC One (satellite) and BBC One (terrestrial) are different channels for the DVBViewer.
