majstang Posted September 1, 2011 Posted September 1, 2011 The new RS version now forces the taskbar ontop just before the balloon tooltip triggers if watching DVBViewer in fullscreen (full screen mode does usually override taskbar ontop), which is just as it should be. However it seems only to be working with DVBViewer. If for example using MPC-HC in full screen mode and a recording starts in background, there's no balloon tooltip showing. Instead the balloon tooltip gets put on hold and triggers when windowing MPC-HC at first.
