Technotrend S-1600 problem with extended diseqc
fundom
Earlier I had Skystar HD2 which was functioning fine with my 8-lnbs via extended diseqc settings in TransEdit. Unfortunately this card went bad. Now I have got TT-S-1600. It has no problem with other sat. viewing programs, but with DVBViewer it is not working with extended diseqc settings. I have the latest bda drivers from TT site. Do I need special settings/plugins to solve the problem?
Thank you Griga for your attention.
Support.Zip attached.
When I got this new s-1600 card, it worked with channel list of two other viewing programs without changing any settings. Extended diseqc configuration worked smoothly. Whereas in DVBViewer neither the already scanned channels worked nor I could configure extended diseqc (TransEdit) to get a fresh list of channels. If I ever managed to get some channels from any transponder, the resulting channels did not belong to that transponder. Would love to get my favourite DVBViewer back to work with this new TT card.
THX & REGARDS,
Griga, many, many thanks - everything works fine now with S-1600 + DVBViewer!
Great!
Edited by fundom
