Compro S900 USB DVB S2 tuner
outofsync
Hello. I would like to report that the above tuner works perfectly with DVBViewer although I'm not using the included remote.
I had purchased a Technisat Skystar S2 card which is not upto the job of receiving S2 transmissions without constant discontinuities.
The Compro receives all transmissions perfectly and is reasonably priced. I purchased from overclockers and wish I had bought this tuner in the first instance. I had been using a Compro S350 for many years without any problems and it looks like Compro have done it again with the S900. :)
